Resets the neighbor-discovery cache configuration parameters to their default values.
| vr_name | Specifies a VR or VRF. |
IPv6 neighbor timeout: 20 minutes
Maximum IPv6 neighbor entries: 1024
Maximum IPv6 neighbor pending entries: 1024
IPv6 neighbor refresh: Enabled
None.
The following example resets the neighbor-discovery cache configuration:
unconfigure neighbor-discovery cache
This command was first available in ExtremeXOS 12.4.
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
